joni
posted on 26/3/15 at 07:16 PM |
Kumho v70a
Hi guys has any one used kumho v70a tyres before would they be good for hills and sprints and track days I no they won't be as stick as avons
a15 but would they do as I have a new set that came on my car thanks jon
[Edited on 26/3/15 by joni]
INDY BIRD
posted on 26/3/15 at 07:26 PM |
used them before and i thought they where great on track very predicatable,
as good as my ao48 i would say
easily
thanks
sean
ps that was on a raw striker
daniel mason
posted on 26/3/15 at 07:27 PM |
The super soft compound which I think may be k21 wouldn't last too long on a circuit. They are mega soft and would be ideal in a road going
class on the hills. But if in modified then a15 or a92 is the only real option
[Edited on 26/3/15 by daniel mason]
joni
posted on 26/3/15 at 07:33 PM |
Thanks guys would they be better than toyo gg
CNHSS1
posted on 26/3/15 at 07:43 PM |
K21 are very close in performance to A15 avon slicks on a modprod or roadgoing car if it has any semblence of suspension travel. If the cars uber
stiff and light then the A15s will be noticeably better.
The A15 compound seems to have a wider heat range envelope though, they heat up as quickly as the k21s, but take longer to overheat in my experience.
The A15 is technically better in cold conditions for first two or three corners of a hillclimb, but most circuit sprints will see both tyres warm at
similar rates
The A15 compound ages quicker though. Buy em at season start and use them at two events or 10 events and the start of the next season the drop off
will be the same. Its highly unlikely you will ever wear the A15s out, but the performance drop off usually forces you to part with 800quid to
BMTR.
the k21s age less rapidly. I beleive the A15 is a 'semi cured' rubber compound. After some heat cycles (few events) they start to cure,
and time does the rest. The K21s are Kumhos F3 'wet' compound which is a normal rubber compound so is cured hence a more stable and slow
performance drop off. They do wear at a fair rate though. If you are serious a newish set to keep for the wets a good idea as the wear rate is so
rapid yhat the grooves become too shallow to dispel water. If you are running in a class where its allowed, then you can cut the v70s to have deeper
grooves to the shoulders. As std the grooves reduce in depth to the outer edges they dont expel puddles well and aquaplane, but cutting the grooves to
a uniform depth does make them good for splashing throuh puddles!
The A15s will be hugely lighetr than the v70s though. If running 13" tyres, and going width for width in comparison, expect about 1/3rd less
weight per tyre for the avons. They use a race carcass, very little steel, mostly rayon and kevlar belting iirc whereas the kumhos have loads of steel
in them. Even at 5psi the kumhos will hold the car up no issue!
CNHSS1
posted on 26/3/15 at 07:49 PM |
For trackdays though k21s will be destroyed in a couple of laps and the A15s maybe only a lap more. Buy cheap s/hand circuit slicks for trackdays. May
take 2 laps to come up to temp, but theyll run all day and usually only cost 20quid a pop!
Kumho mediums might be ok if you cars uber light, 350-400kg for trackdays, but would be hards ideally. They wont be as good as cheap ex circuit
slicks though.
For sprints and hills the toyos are average at best, ao48s little better. I used toyo SGs and the grip wasnt a patch on kumho k21s, were barely warm
on hills as you crossed the finish, only anglesey and castle combe spribts really allowed them to work reasonably well.
If not kumhos, look at Avon ZZRs, only real competition for the v70as
joni
Just west out to workshop and the stamp on the tyre is k61 so noing my luck there as hard as a goats toe
joni
posted on 26/3/15 at 07:54 PM |
Found out med compound what tyre pressure westfield car engined do you guys think iam used with toyo and bike engine for racing and would have used
17 psi cold
CNHSS1
posted on 26/3/15 at 08:13 PM |
I run 20-22psi but on a heavier car so have less issues with getting heat into the fronts. I would say 17-19psi for sprints will be a good starting
point. What sizes are you running btw?
There are some k21 v70s on ebay now which have been cut to wets, compare the tread patterns and youll see what i mean.
The k61s may be ok for trackdays if they are a bit old, should slow down the overheating
Whitti_uk
posted on 11/11/15 at 12:09 AM |
I used to be sponsored by Kumho. I have used the soft compound and medium compound V70A... I found they were softer than the compounds suggested. The
C03 was my Kumho tyre of choice which was a semi-slick rally tyre... worked well and punched above its weight alittle against the Dunlop X10/12 most
my competitors were running. This was all in an Evo though. Friend does well on hill climbs with the V70a
PaulM
posted on 12/11/15 at 09:29 AM |
They're great until it rains! I used to race in the Kumho BMW Championship and have had my fair share of trying to race them in the
wet.....they're useless!
