Locost82
| posted on 28/2/05 at 12:41 PM |
Spring Rates
The Champion book suggests the best spring rate for racing is 300lb/in, and a suspension book I've read supports this figure for a
Caterham-sized car.
In my garage I have a big box of springs, ranging from 150 to 400lb/in. Will I get any benefit in moving towards harder springs? Will it increase
grip or merely reduce roll? Does it make any difference?
DavidM
| posted on 28/2/05 at 01:01 PM |
Depends what engine etc. you are using.
300 on the back sounds a bit hard to me. I think if you use 400lb you might need to get your fillings tightened.
Proportion is Everything
JAG
| posted on 28/2/05 at 01:35 PM |
My Stuart Taylor car has 275 on the front and 150 on the rear - recommended for general road/trackday use. The rears are so low because I have a
live-axle.
I guess slightly harder would be expected for a 'racing' car.
Justin
GParkes
| posted on 1/3/05 at 01:18 PM |
My car has 400 on the front and 180 on the rear. I think you can run the front softer if you have a front anti roll bar.
If I were to change the springs I would try them softer on the front and rear. But thats not in the budget just yet!
Gavin
