Robster
| posted on 19/8/05 at 08:37 AM |
Carb Query
I know that this is one of those topics that has probably done the rounds before, but it's been bugging me for a few days & I can't
find any answer!
I'm builing for the 750MC Locost races series, and know that the regs stipulate that either a single or twin choke carb may be used - I have a
1300 non GT engine that I'm in the process of rebuilding, which has a single choke carb. What do most of you racers use, the single or twin
choke carbs?
I seem to recall previous posts here (or on the yahoo list?) that the twin choke carb was the way to go - is this the case or is my memory letting me
down? Is a twin choke carb really going to make that much difference?
If twin choke is the way to go, anyone got a spare inlet manifold with twin choke carb they want to sell?
Rob.
Locost82
| posted on 19/8/05 at 11:54 AM |
I use a twin choke and it seems to do the job. I think most racers use them.
Robster
| posted on 22/8/05 at 11:32 AM |
That's what I feared! I've got a single choke one with my donor engine, but can't seem to find a twin choke... have to keep on
looking!
stevebubs
| posted on 22/8/05 at 12:04 PM |
looking!
Normally a twin choke or 2 on ebay at any given time
search for
xflow carburettor
crossflow carb
escort inlet
DGAV manifold
swap around the above keywords sensibly until you get a hit.
Robster
| posted on 23/8/05 at 11:05 AM |
Yes, I have been looking on ebay, but am not fully clued-up on carb terminology, so not 100% sure what I am looking at!
First step me thinks is to do some more reaearch - anyone recommend a good carb book or website?
ernie
| posted on 24/8/05 at 04:11 PM |
get peter wallage book rebuilding & tunig ford kent crossflow engine. it has a section dealing with twin choke webber, including very detailed bit
for stripping & refurbishment. it does not matter if its auto or manual choke cos you discard them but make sure the venturi sizes are 23/24 to
comply with regs. I think you can change them but I`m not sure. I`mjust about to dismantle mine cos its running very rich proberly something jammed
after hitting the tyre wall at Pembery (own fault)
Robster
| posted on 24/8/05 at 06:36 PM |
i've got the wallage book and you're right it h as a great section on dismantling a twin choke.
But I'm coming for a very low knowledge base on carb's here... I didn't know until today what the "32/36" in a DVG 32/36
carb meant. I'm still trying to find out if you can change the venturi, as that will make buying a second-hand one a lot easier - i have come
across a few DGV or DGAV, but none with the right size venturi!
Do you know if all DVG carbs will fit onto the GT manifold?
Are you going to Silverstone this weekend; I am going to be there, would be useful to find you for a chat.
Rob.
ernie
| posted on 24/8/05 at 06:57 PM |
Rob ,your knowlege is the same as mine at this stage. my 1st season and a big crash means no Silverstone cos I`m trying to reassemble car its almost
there apart from the engine not running cleanly. and very rich. so my first time to pull apart carb and hope for the best. I will be at brands if this
works
ernie
| posted on 24/8/05 at 07:35 PM |
ps there is a place in Leighton Buzzard, that does carbs and spares and should know if can change venturis, as far as I konow all carbs should fit the
gt manifold
ernie
| posted on 24/8/05 at 07:37 PM |
pps the carbuerter exchange company
Robster
| posted on 25/8/05 at 07:50 AM |
Cheers Ernie, I'll give them a call today. Good luck with the rebuild...
ernie
| posted on 4/9/05 at 02:53 PM |
took the carb apart & put it together again no prob, venturi are part of the body, before dismantalling get a service kit and power valve
diaphram
stevebubs
| posted on 4/9/05 at 05:11 PM |
Take a look at ebay items
4572728930
4572999796
4573213635
4573086762
4571794020
7997263007
HTH
S
Robster
| posted on 5/9/05 at 12:51 PM |
Thanks for the tips Ernie. And thanks Steve for the e-bay listings - I have found a carb & manifold with the regulation venturi sizes, next step
is to dismantle & refurb.
Must re-read the section in the Wallage book - assume it is fundamentally the same even though it discusses the 32/36.
Rob.
