Author: Subject: Dash data logger.......
Jon Ison
posted on 13/11/05 at 07:39 PM Reply With Quote
Maybe of interest too you guys....
ebay number 8014732402
Avoneer
posted on 13/11/05 at 08:40 PM Reply With Quote
Jon,
Is this suitable for SVA?
Just wondering if it has any benefits over using my Blade clocks?
Does it only work off batteries?
Pat...
Jon Ison
posted on 13/11/05 at 09:14 PM Reply With Quote
the only bit that uses batteries is the beacon transmitter that can run off a 12v car battery or loads a little ones, never used beacon transmitter as all tracks have one anyway, for road use it IMHO would be ott as the main brains of it are data logging etc........as for SVA all the functions you need are there, adjust speed during test and (don't hold me too it) the dash would/should pass the radius test without recessing it into the dash, if that makes sense.
its the kart one that uses batteries for the dash unit, that's a mistake a lot of people make.
Avoneer
posted on 13/11/05 at 09:36 PM Reply With Quote
Hi Jon,
Would only be for road use, so think I'll pass - thanks for the info anyhow.
Pat ;-)
