andrews_45
| posted on 18/4/06 at 08:13 PM |
wishbone drawing (2nd edition of book)
Phew, sorry... me again
I have the second edition of uncle rons book, but I have read about the wishbone dimensions being out. Was this updated for the second edition? or
are these still out.
Please see pics...
I have read on other posts that in the 1st edition of the book, the wrong offset was put on the top wishbone caster. Could anybody pls confirm if
this is a updated/correct drawing that I have. Ta
Oh... and IIRC I want to be making them from 14 or 16swg?
James
| posted on 18/4/06 at 08:24 PM |
It's the top wishbone that's out.
And yes, it's still out in the 2nd edition.
Just make the castor offset 22mm and not the 11mm that's pictured above.
Unless you're using Sierra uprights for which it should (allegedly ) be 25mm.
HTH,
James
[Edited on 18/4/06 by James]
- Muhammad Ali
flak monkey
| posted on 18/4/06 at 08:37 PM |
As james says.
The upper wishbone should have an offset (toward the rear of the car) of 22mm, not the 11mm shown on the diagram.
Basically make the larger dimension 132mm and the smaller one 90mm and you wont be far off.
Sera
http://www.motosera.com
SeaBass
| posted on 18/4/06 at 08:39 PM |
Just be careful guys those scans are in breach of a current copyright...
907
| posted on 18/4/06 at 09:07 PM |
Yup, this is what I've used.
Paul G
Chippy
| posted on 18/4/06 at 10:29 PM |
Hi all, sorry to highjack the thread, can someone confirm that when using Sierra uprights that the offset should be 25mm, because if this is so then
it's a new set of top bones I need to make. atb Chippy
James
| posted on 18/4/06 at 10:58 PM |
I'm basing it on some posts/data that Mark Allanson put up in the past.
Worth checking with him.
Can you not use washers/spacers to set the castor the 3mm you need?
James
- Muhammad Ali
| posted on 19/4/06 at 07:08 AM |
Just move the upper brackets as far as you can towards the rear, exact caster (or to use the term bikers use "trail" ) isn't
that critical but it must be the same both sides.
[Edited on 19/4/06 by britishtrident]
Syd Bridge
| posted on 19/4/06 at 08:54 AM |
quote: ... exact caster (or to use the term bikers use "trail" ) isn't that critical but it must be the same both sides.
ERRR......Castor and trail are two very different things.
Caster is the angle of the kingpin axis to the longitudinal vertical.(ie Viewed from the side.)
Trail is what you see on supermarket trolleys, and is the rearward setback of the axle itself from the kingpin axis. (ie. The axle c/l is not
concurrent with the kingpin c/l, but is set back from it.)
Both have very different effects. I would choose more caster every time, before I entertained 'trail'.
Syd.
| posted on 19/4/06 at 09:02 AM |
Where's the 11mm?
I make 121-102=19mm. The two measurements converted to metric don't add up to the 222mm for the overall width so use one or the other.
flak monkey
| posted on 19/4/06 at 09:22 AM |
Offset is taken from the centreline of the wishbone. The centre of the wishbone is at 111mm (222/2).
121-111 = 10mm. So the offset actually shown in that diagram is 10mm not 11. (oops )
[Edited on 19/4/06 by flak monkey]
Sera
andrews_45
| posted on 19/4/06 at 10:31 AM |
Ah, thanks. That was where I was getting confused. So 22mm it is.
Nice one chaps ta
| posted on 19/4/06 at 02:01 PM |
Me too..
Mine's been done 5 years and works o.k. so I'll not worry about it now .
| posted on 19/4/06 at 06:59 PM |
A lot of the dimension in the book weren't converted from imperial properly -- really shows on the chained dimensions.
| posted on 19/4/06 at 07:03 PM |
snip
Syd.
Actually not true but I don't argue just for the point of causing trouble.
MakeEverything
| posted on 16/10/08 at 09:43 PM |
British Trident,
Is it not 'Rake' your thinking of? As you can have Rake AND Trail on a bike.
If i remember correctly (Not wishing to start an argument)
Castor - The rotation of a single axis
Camber - Toe in or Out
Rake - The angle of an axis from another
Trail - The distance of and axis from another
I could be wrong though.
Kindest Regards,
Richard.
MakeEverything
| posted on 17/10/08 at 04:11 AM |
Not many things keep me awake, but this did! Ive checked this, and i am correct. My explanation isnt very clear though...
Castor - Rotation of a single axis from vertical
Camber - Toe in or out
Rake - The longitudinal angle of an axis from vertical
Trail - the 'offset' of one axis from another (ie not in line). Measured in distance, not degrees.
Kindest Regards,
Richard.
