GavBurns
posted on 4/12/06 at 02:46 PM |
Fireblade firing problem
Hi
When my locoblade is running it sounds a bit rough and I noticed that the carb trumpet above cylinder 2 was popping so I took the HT lead off cylinder
2 whilst the engine was running and it made no difference at all, so I thought that the cylinder wasn't firing, I took the plug out and it was
sparking like hell. I don't know what is causing it.
Anybody had a similar problem or know what the problem is??
[Edited on 28/11/06 by GavBurns]
Go BEC you'll never look back (literally)!!
Agriv8
posted on 4/12/06 at 02:57 PM |
sound coil pack problem.
is there a spark on the other spark plug from the same coil pack ?
can you swap the two coil packs over and see if the pronlem moves with the coil back ?
regards
agriv8
GavBurns
posted on 4/12/06 at 05:06 PM |
I'll try it!
the_fbi
posted on 4/12/06 at 11:17 PM |
Depends which cylinder you call #2, but the one 2nd from the gearbox output shaft end has a small air bleed pipe under it which can lean off the
mixture if not blocked off.
