ironside
| posted on 2/2/07 at 03:53 PM |
L Assembly
For those who built their own race chassis . . .
Are the McSorley book plans of the L assembly the ones to use for the 750mc locost series? ie a 3" lean?
From searching the forum there's all sorts of info pointing to mistakes in the book, changing the amount of lean L has and/or moving Fu tubes
that I've got my head in a knot thinking about it. The 750mc regs don't really clear it up either.
Thanks,
James
| posted on 2/2/07 at 04:32 PM |
The Mcsorley 'book' plans are just that, the book plans but with tube lengths corrected.
From memory 3" is correct so go with that if that is what you *have* to do for the 750.
James
EDIT: The business of putting it an extra inch back is to get the upper wishbone brackets to fit better. But this is a modification of the book plans
rather than a necessary 'correction'.
... if you see what I mean...
[Edited on 2/2/07 by James]
- Muhammad Ali
ironside
| posted on 2/2/07 at 07:53 PM |
Your edit clears it all up - thanks.
Simon W
| posted on 19/4/07 at 05:56 PM |
I am having an absolute nightmare trying to get the L assembly put together. Top and bottom rails done ofcourse, just the compound cuts on LA and LB
are really causing me headaches. Can anyone tell me a good way of making these cuts? I am trying to use a standard chopsaw with angle set and then
manually proping the bar up in the jaws to try and get the right angle. Not pretty!
[Edited on 19/4/07 by Simon W]
