andrews_45
| posted on 8/2/07 at 12:36 PM |
p103/104 Kent cam
My cam has arrived from Kent but I cannot find the 103/104 marking anywhere. I thought that that was the main reason of having to buy one? so to get
the stamp.
Where are others marked up?
Also what does the kit consist of for the locost race series. I got some Lube, a cam and followers...
Ta
procomp
| posted on 8/2/07 at 12:41 PM |
Hi should be marked on the fuel pump lobe.
But it is usually not verry easy to see which kinda defeats the object some what .
cheers matt
D Beddows
| posted on 8/2/07 at 12:47 PM |
You did mention to them that you needed a cam for locost racing didn't you.......? The Locost racing cams have a number scratched on the
mechanical fuel pump drive lobe if I remember correctly so they can be easily checked by scruitineers. If it hasn't got that number scratched on
it then it needs to go back to kent
*edit* It would appear Matts on the ball today
[Edited on 8/2/07 by D Beddows]
procomp
| posted on 8/2/07 at 02:23 PM |
HI " It would appear Matts on the ball today "
Only beat you by 6min must be the snow slowing your conection down dave .
cheers matt
andrews_45
| posted on 9/2/07 at 10:56 PM |
Nice 1 found it, looks a bit crappy! How would the 750mc be able to tell that apart from a etch by any other person I cannot understand.
It would have been incredibly easy to machine the fuel pump lobe off myself at work and etched it myself. It has no kent stamp on it, just been
etched using a pneumatic scribe...
simes43
| posted on 10/2/07 at 12:02 AM |
The cam goes back to Kent and is checked. You are then issued with another one. Nice
