cloudy
posted on 28/11/07 at 11:39 PM |
Wilwood front uprights
Anyone used these - any idea on the weight saving?
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=1375_1594_1595&products_id=13605
Are these designed to be compatible with cortina uprights?
James
mookaloid
posted on 28/11/07 at 11:42 PM |
from Wilwoods site
Designed for use in fabricated A-arm suspensions on kit cars, street rods, drag cars and other custom or race applications configured around
Pinto/Mustang II suspension geometry.
linky
cheers
Mark
cloudy
posted on 28/11/07 at 11:56 PM |
saying that, just seen these beauties
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=1375_1594_1595&products_id=11815
looks competitive price wise against raceleda?
RazMan
posted on 29/11/07 at 08:06 AM |
That last upright looks interesting - can't believe I haven't spotted them before.
I wonder if they are stronger than the 750kg weight limit of the Raceleda jobbies.
[Edited on 29-11-07 by RazMan]
Raz
cloudy
posted on 29/11/07 at 10:44 AM |
Is suppose that limits you to custom made wing stays?
Syd Bridge
posted on 29/11/07 at 11:16 AM |
I'd go for the Wilwood items every time.
Pinto/Mustang 2 geometry and sizes are close to Cortina.
Also, the Wilwoods have a ONE piece steering arm, so no dodgy(albeit pretty) welds to hang your life on.
Also, note that the Wilwoods are priced as PAIRS. £125 for the pair with steering arms is very good value.
Syd.
posted on 29/11/07 at 12:52 PM |
Incredible value. Do you know if the balljoint tapers are the same as the Cortina upright?
cloudy
posted on 29/11/07 at 03:31 PM |
Only problem is it's all steel - so I wonder how much weight would actually be saved against the cortina unit?
PS. The RMD ones are also priced as a pair...
J
Syd Bridge
posted on 29/11/07 at 04:16 PM |
Now, I know everyone will jump on me for this, but.......
Those ally uprights STILL have not got any testing certificates. The problem with ally, is that it ages, and with time will crack and fail, showing a
pronounced granular structure.
Motorsport parts are lifed, and for good reason, as are aero parts.
Yes, some motor manufacturers use alu, but not the same stuff that these items being sold by a couple of people are made of.
As for the tapers, I don't know for sure, but Ford use the same taper universally, as far as I know, with only a couple of exceptions usually of
japanese origin.
If you MUST buy these alu uprights, ask for a copy of the strength test certificates, as well as the metal composition and heat treatment certs. If
you can't get all those bits of paper, then the outcome is entirely up to you.
I've been trying for a long time to get these people producing the alu uprights to act responsibly, and get the uprights properly tested and
certified.
To date, I am unaware of anyone who has done so, including Rally Design. (Mr. Elderfield may wish to show me as being incorrect in his case, which I
would welcome.)
A properly designed alu part for road use will be very bulky, and at least as heavy as a steel item, because of impact and fatigue issues which must
be factored into the part.
Syd.
[Edited on 29/11/07 by Syd Bridge]
bj928
posted on 29/11/07 at 06:47 PM |
i'm using them, they are very nice and fit straight on to arms top and bottom.
pathfinder
posted on 29/11/07 at 08:43 PM |
I’m with Syd on this one.
Another point for concern is that (to the best of my knowledge) neither retailer of ali uprights manufacture in house.
Paper work only goes so far and you should never trust a sub contractor 100%, if corners can be cut they usually are!!!
The thought of home brew ali uprights scares me, I’d go for the Wilwoods.
