Jon Ison
posted on 25/3/08 at 08:20 PM |
Fireblade dip stick ?
I though I knew but after a conversation today can someone clarify please ?
Oil level on a fireblade with dip stick (no sight glass)
Check screwed fully in or sat on top thread ?
blue2cv
posted on 25/3/08 at 08:26 PM |
Always used to be sat on thread when i was a lad, no doubt someone will put me right if things have changed
posted on 25/3/08 at 08:27 PM |
Sat on top of threads. ie, not screwed fully in.
Phil
[Edited on 25-3-08 by Hellfire]
ch1ll1
posted on 25/3/08 at 08:28 PM |
screwed in !
hobbsy
posted on 25/3/08 at 08:31 PM |
On the Blackbird it was sat on threads.
Not a Fireblade admittedly but still Honda... ![](/images//smilies/smile.gif)
mark chandler
posted on 25/3/08 at 08:33 PM |
Scewed in for me as well, so thats 50:50 chance of getting it correct from the other posts, but I am sure I am correct as I looked it up last year.
If I put to muh in my BEC the clutch slips so I have it 1/2" over the top level.
ChrisGamlin
I always thought it was on threads.
posted on 25/3/08 at 08:40 PM |
Checked the manual and it is sat on top of the threads.
Phil
trifield
posted on 25/3/08 at 09:15 PM |
My manual also says sat on top thread.
Coose
posted on 25/3/08 at 09:21 PM |
I've never known a bike dipstick not to be sat on top and screwed in when checking the oil, including two-stroke gearboxes!
Spin 'er off Well...
Crazy Eddie
posted on 26/3/08 at 08:42 AM |
If you didn't screw it in then you wouldn't have to fill it 1/2" over the top level
On threads for me and then up to max plus 250ml if going on track
www.EdwardsSchoolOfMotoring.co.uk
For online shopping that earns you money : Ei42.com
moochofun
posted on 26/3/08 at 03:23 PM |
Crikey, learn something new every day!
Will go home tonight and measure it out properly then (will refer to the Haynes manual as well just to confirm as there is a mixed response!)
Ta
PS Maybe that's why my last engine didn't last too long then? ![](/images//smilies/sad.gif)
MikeCapon
posted on 26/3/08 at 03:45 PM |
Another vote for not screwed in. I've worked on Jap bikes for the last 30+ years and that has always been the case.
www.shock-factory.co.uk
moochofun
posted on 26/3/08 at 08:06 PM |
Ta
Just been down to the garage. Haynes bible also confirms that the dipstick should not screw the dipstick back in when measuring the oil level! Luckily
I had overfilled it slightly (or so I had thought) for the trackday down at KH last weekend. So all is in order
Thanks for the info!
