ernie
posted on 17/12/03 at 06:40 PM |
silencer/cam
I need silencer for race car considering demon tweeks any advice? also what are the regs for 2004 regarding cam?
efairba1
posted on 18/12/03 at 06:23 PM |
2004 Technical Regs can be found at:
www.desandalracing.com
As for silencers, no idea what the DT one is like, but Stuart Taylor, and Luego, and a number of others will sell you a complete system. They are
wildely used in the championship.
Des
blackie
posted on 18/12/03 at 07:26 PM |
Your camshaft must be purchased directly from Kent Cams. You have to tell them that you want it to race in the Locost series. They will then mark
the camshaft on the fuel pump lobe (so get yourself an electric fuel pump too!) to signify that the cam is 'pukka'. Correct cam marking
will be checked by the scrutineers.
No other cam is acceptable. If you already have a P103/4 genuine Kent Cam, you can send it back to them to have it marked.
This is all an attempt to level the playing field & eliminate the time honoured "I didn't know" excuse!!
Best of luck for the 2004 season.
DB
