Estimating Clutch Release Force?
cloudy - 26/2/15 at 10:14 PM
I'm trying to analyze stress on a bike clutch slave mounting plate, and want to estimate the likely force required to release a GSXR 1000 clutch pack - the actuation is direct with no leverage. Any good ideas? I can't find any information on the rating of the springs, let along the preload
Any help welcome!
Thanks,
James
bi22le - 26/2/15 at 11:04 PM
But some weighing scales from a fishing shop and give the lever a tug? !?
cloudy - 26/2/15 at 11:50 PM
It's hydraulic via a push rod - doubt I could do it by hand! Not got the hydraulics piped up so can't test for pedal effort and then work out the ratio
cosmick - 28/2/15 at 09:48 AM
What model of GSX R1000 is it and are you trying to make a cable clutch instead of hydraulic?
cloudy - 28/2/15 at 02:39 PM
K1/2 - converting cable to hydraulic
cosmick - 28/2/15 at 11:13 PM
I think you will find that a K7/8 Sprocket cover will fit your engine and it uses a Hydraulic cylinder. It will save you a lot of work and calculation. Are you fitting a prop shaft. If so you could probably cut the area to accommodate.
