Has anybody got any pics of where they keep there tax disc on there mk indy?
cheers Des
best off using a motorcycle tax disk holder
I use one of those alloy jobbies with slightly longer stainless dome heads going through the bodywork on the side of the scuttle, its a 15 minute job too change the tax disc but its only once a year, don't think I have a pic.
You can just see it on this pic........
Some one was selling them on here a while back for not a lot.
I bought a tax disc holder for a motorbike, then attached it to the upright section just inside the passenger side with a bit of velcro.
Not a permanent fixture, but much easier to take off and put in my pocket!
If you need, let me know and I can supply a pic.
Peter
Between the seats on the rear bulkhead. Three longer bolts are used to secure it. Picture
here
Phil
Great Minds
At the post office
Mine's on the scuttle on the passenger's side
Here's a bit better pic, also shows current state of play with rebuild, decided too fit a new panel on the passenger side, bit more work but
worth it.......
I use a motorbike type holder, bolted onto the near side of the dash panel facing the passenger. Probably not SVA friendly though, and I think
technically they might be supposed to face forwards? Ah well
My dash with Blade clocks
[Edited on 25/2/07 by ChrisGamlin]
