hi all
i have fitted my copper fuel line
do i need written proof that the flexi that connects to the tank and carb is right grade or will whats stamped into it be good enough
cheers
colin
hi, i got written proof about my fuel hose from my local motor factor teh chap was more than happy to help, but i am not sure if you need it. if you
have not brought the hose yet try your local motor factor, they might give you a photocopy of there catlogue say what it is fit for and all the
numbers, because that is what mine done.
stuart
If its marked with the correct markings it will be fine. If not, you'll need a reciept or something to prove its fuel resistant.
Most rubber fuel hose is marked.
