are dash switches (eg fog light) required to be identified with a symbol or text? or can they just be blank?
also, are they requried to illuminate when active and/or be backlit (I assume this will be required)?
cheers
Should be marked as you suggest plus they should light up when active
[Edited on 13/2/09 by Mr Whippy]
No, in general not for SVA. However, brake warning light must have symbol and a few specified controls must have a tell-tale which lights up when the switch is on (e.g. fog light, main beam)
IVA introduces the requirement for switches/telltales to be marked. The symbols required are in the IVA manual draft.
Switch isn't required to light up when active, but if it's got a light in it then it can be a telltale.
