where is the front indicator position 400mm measured to? the outer edge of the light surface,the inner edge or the centre, ie: is it on the lenient
side or does the whole light surface need to be within 400mm
James
outer edge of the lamp
[Edited on 26/2/09 by Mr Whippy]
Just remember they use the widest point of the car to measure the 400mm from - that can be the rear wheel arches and has caught many people out who measured from the front arches!!
Excellent news, luckily my front and rear setup's are identical in track and wing type
