How does everyone get their wing edging to be smooth around the corners of the wings? Mine juts out where the turns are too sharp.
i cut a little V out of mine
Then that's just what I'll do!
Push it on really well?
Use stuff with a stronger 'grip'?
Didn't have to cut v's in mine.
James
It sound as though are using the smaller trim use the larger one with the metal grips inside and it will stay on. Barry
Round of the corners of the wings with a bit of emery to lessen the angles
Trim i used had glue in it. When warmed up stuck nicely. As Rich says - rounded edges help. Some trim is softer than others too.
