Postie delivered the tax disc and plate permit this morning, so straight into Barnstaple for the plates.
Went out for a shakedown - brilliant!
Ignition is a bit off and consequently slight overheating.
Unfortunately I then put a hole in the auto-box pan, by misjudging a gate-retaining tube in the driveway.
autobox...
well done and just in time for the sunny weather. Im still waiting for the DVLA guy to inspect mine and then have a retest on 29th April. Just got to sort a few minor items.
Originally posted by cd.thomson
autobox...![]()
I just clipped the leading edge of the pan on the sticky-uppy pipe/tube that holds the gate closed - and dumped 3 litres of ATF on the floor! Two
inches to the right and I'd have missed it!
Having pondered the matter, I'm going to do it properly and remove the pan to weld up the split. It's only about 1/2 inch but I won't
be completely happy if I try to do it in situ.
Originally posted by MautoK
I just clipped the leading edge of the pan on the sticky-uppy pipe/tube that holds the gate closed - and dumped 3 litres of ATF on the floor! Two inches to the right and I'd have missed it!
Having pondered the matter, I'm going to do it properly and remove the pan to weld up the split. It's only about 1/2 inch but I won't be completely happy if I try to do it in situ.
