SVA on 17th some photos in my
PHOTO ARCHIVE UNDER SVA
for your comments please...Have I missed anything obvious etc
is that a collapsable boss that the whell is on? and do you have any padding for the centre metal bit?
rear reflectors?
Far too clean!!!
Tie wrap bases for battery wires stuck on with sticky foam pad, I think they need to be "permantly" fixed. Either riveted or I used PU
adhesive which was OK.
Cycle wing rear edge needs to be below the level of the wheel centre. Take some home made mud flaps to stick on if he spots this. My tester
didn't spot it on mine.
It will need some edge trim around the harness triangles.
Steering wheel pad?
Is the shock adjuster sharp?
Can he get his ball on the cap head holding on the exhaust, or the sharp looking ally plate (Exhaust1)
They might not like the (pipe foam) on the bottom of the headlights as it looks a bit temporary.
Other than that looks a nice neat job.
Originally posted by Slater
Cycle wing rear edge needs to be below the level of the wheel centre. Take some home made mud flaps to stick on if he spots this. My tester didn't spot it on mine.
Rear Reflectors are around brake lights inner set.
Putting Seirra steering wheel on for test.
AFAIK the mudguard only has to cover the RIM in plan view.
[Edited on 10/4/09 by ReMan]
I would watch out for the mirror falling off at an inopportune moment.
I have the same one on my windscreen at the bottom, and every few weeks it decides it has had enough and throws itself into the passenger footwell
The width of the mudguard must cover the tyre (including sidewalls) in plan view - I had a few mm of sidewall visible and had to
'adjust' the stays to comply.
The leading edge of the mudguard must be forward of the rim.
Not sure about the back edge (re. above/below axle)
John.
Looks very tidy.
Just a couple of things...
Edge trim on harness ends. I used small edge trim and tucked the ends in under the belt loop.
Pipe insulation on front suspention. Think someone tried this last week and failed.
Foam and cable ties on the suspension may not be "permanent" enough.
Are the front indicators high enough, close enough to the outside edge and visible from the required angles?
Nice car.
For our shocks I cut up a old inner tube into one inch strips about 9 inches long.
One end i stuck with evostick to the top of the shock and then progressivly wound round gluing to itself and managed to cover all the sharp bits at
top and then did the same in the other 3 places on both shocks.
For the top ball joint i used a cable gland cat at both ends, stretched over the threaded bit and the wishbone, held it self all this time to stop
water getting in.
Good luck
Headlamp bracket could do with some edge trim but nice looking car very neat . tester will like it good luck
