Ive been doing a search,but have got myself well and truely confused......Again!
I only thought there were 2 options for plates:
These being age related and Q plates.
Now i have found that you can get a new plate:
How do i go about this?
Aaron
Build the car with new parts. IIRC you may be able to use one reconditioned item?
Can you recon them yourself?
Such as rebuilding the engine?
You'd have to prove that you'd rebuilt it to an "as new" condition, BigRich got a new plate on his car, he might have more
info.
Chris
All major components must be new, with the exception of one that must be "reconditioned as new".
Whether doing the recon' yourself would be accepted would depend on the DVLA bod dealing with it.
adrian
http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_10014246
Kit Cars
Where all the parts of a vehicle are supplied new by the manufacturer. Subject to the provision of satisfactory receipts and a certificate of newness these vehicles will be registered under a current registration mark.
Kit cars which have been built using not more than one reconditioned component will also be registered under a current mark. This is subject to the provision of satisfactory evidence that the component has been reconditioned to an "as new" standard. An IVA, ESVA, SVA or MSVA test will be required.
Originally posted by iank
If you don't get a new reg you'll be on a Q as you won't have a donor.
I built my car with some new, some 2nd hand and some reconditioned parts. After DVLA inspection i went to motor factors and got new plates. Couldnt find any 2nd hand ones with the correct letters and numbers.
I got new plate using one reconditioned part ( also on the bottom of my log book it says, special note CO 3.5 HC 1200 ).
My R1 was accepted as my recon part. I put a note with my application stating that they engine and box were ONE integral and inseparably unit.
Wasn't questioned and I got an 08 plate.
Others haven't been as fortunate however. Just comes down to who deals with the application.
adrian
'I built my car with some new, some 2nd hand and some reconditioned parts. After DVLA inspection i went to motor factors and got new plates.
Couldnt find any 2nd hand ones with the correct letters and numbers.'
lol
That raises a question, my "donor" is currently being stripped for parts, then the engine and such will be headed for my garage. Do I just have to prove the engine came from a car as I'm not sure if he'll even have numberplates on it at this time (keeping the private plate he's got on it)
I'd rather have a K than a Q
I'm getting worried now because we were told by a woman at the DVLA at swansea to scrap the vehicle even though we want an age related plate.
We then submitted the application with a photocopy of the V5 which the woman queried when she rang for appointment.
Oh well I guess Ill find out friday
I think you can scrap the donor - as in dispose of the bits you dont need - but you keep the V5 as a live document and dont surrender it. The downside is that you have to keep SORN running but the positive is you have the correct donor paperwork to hopefully qualify for age related plate should that be your desired choice.
In that case the woman should have made it clearer cos the wife surrendered the V5 but not before taking a photocopy
I got an 08 plate declaring the engine as reconned.
Emmisions are set at 1993 for the original engine date and tax is £185 for a car over 1500cc.
V5 states at the bottom that all parts may not be new.
