Long term insruance in Europe?
tegwin - 8/5/09 at 10:03 AM
My sister is thinking about buying a van for carrying biking/climbing/camping gear around europe...and to sleep in...apparently..
She is planning to spend the next 4 months in Switzerland before comming back to the Uk to work... although she will be making regular trips to the continent in said van ...
What is the best way to insure the vehicle? It must be possible to do it without being bent over and penetrated!
ashg - 8/5/09 at 11:49 AM
direct line give 90days as standard. best thing to do is to ring round and see if it can be extended.
dogwood - 8/5/09 at 12:43 PM
there are 2 options,
neither are of any use I suspect.
SAGA give full European cover for as long as you like.
Got to be over 50 though.
Get the vehicle registered over there.
Got to have address there though.
I had same problem when I started going to France.
With the exception of saga, noone did more than 90 days with out you being as you say " Penetrated"
Humbug - 8/5/09 at 02:50 PM
this bunch claim to give you 365 day European cover
