If I've read it right, the manual says the headlights have to be 400mm from the widest part of the car same as the indicators IIRC). Does it mean
the centre of the light or the outer edge?
JB
400mm is not an instruction it is the maximum permitted distance from the widest part of your car and this can be your rear wheel arches.
The measurement is to the outermost edge of the lense.
I recommend that you get it inside of the lense.....
this might help
Front lighting
Cheers chaps
Originally posted by chris_smith
this might help
Front lighting
this might help
Front lighting
I STILL disagree with the 400mm in from the edge for the indicators.....
older diagrams showed only this measurement for the side lights not the idicators.
