A quick one coz i'm on a break from work, posting this on my phone, what diameter cable is considered ok for handbrakes? Is it 2.5mm?
Also, i've got sierra calipers which normally have a closed hook fitting on the end, but would a clevis with a pin through it to make a similar
fitting be ok maybe? The original mini had a clevis with pin fitting iirc...
Photos when i get home at 11 tonight.
see you're friendly AA man and ask him to sell you a couple of the closed ends, Oh poo forgot you're a jock aren't you , well see if
he'll donate a couple.
tony
i need to get cables made up by someone. mine are to be too long to use any normal standard sierra ones modified.
i've seen a company who are a lot cheaper than speedy cables, but in case they can't come up with the exact fittings, just wondered if any
of these would do
http://www.rdb93.co.uk/technical.htm
can't see why not, but have a word with an AA man they have a huge kit of cable and fittings including sierra type ones that they use for clutch
and throttle cable get u home repairs. the fittings are held onto the cable by 2 grub screws, had no problem with SVA using them
This is the firm that supplies the AA
tony
[Edited on 17/9/09 by mad-butcher]
