After reading a number of posts and then the IVA manual it looks like the side repeaters in the scuttle will not pass the IVA.
Link to pic
So I need to mount another set -
As it has to be within 2600mm of the front it has to be on the front wings? Has anyone passed with their side indicator there?
The problem as far as I can see it is I am only supposed to have one side repeater on each side??
How would it be to disable/remove the current side indicators just for the test then put them in afterwards?
Frank
[Edited on 13/3/10 by FrankP]
i passed with them on the scuttle.
got them up really high though so they cleared on visibility over the rear arch.
got any pictures?
AshG passed with them on his scuttle.
this is what adrian h did to get round making another hole on his scuttle
you must have 2 front indicators, 2 side and 2 rear indicators
but you can also have 2 additional side marker lamps towards the rear between the side and rear indicators and 2 side marker lamps towards the front
between the front and side indicators, to compensate for your required lights not achieving all the viewing angles.
[Edited on 13/3/10 by ashg]
failed my iva on this.
moved them to rear edge of front wheel arch
www.tigeravon.co.uk
something like this would work, if the mirror was iva compliant.
http://cgi.ebay.com/ebaymotors/CUSTOM-CHOPPER-LED-MIRRORS_W0QQitemZ350322030905QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item5190d1f9
39
I'm thinking about mounting some on the lower part of my rollbar, only thing I'm not sure of is how to make it "permanent" as far
as IVA man is concerned but not damage the rollbar so I can take them off after. Thinking of something like
THESE
Either that or might just leave them there, I just think they look "odd" on the rear arches.
[Edited on 14/3/10 by eznfrank]
