Dash... MOT Requirements?
scootz - 28/8/10 at 04:50 PM
What instruments and tell-tale lights does the dash NEED to pass an MOT?
Ta!
Peteff - 28/8/10 at 07:02 PM
Speedometer, main beam, indicators and brake fluid tell tale.
omega 24 v6 - 28/8/10 at 07:16 PM
and fog light
bigrich - 28/8/10 at 07:31 PM
foglamp telltale, indicator/hazzard telltale, abs lamp if abs fitted.
scootz - 28/8/10 at 08:05 PM
Cheers... so just to re-cap so I get this right, the only instrument needed is a Speedo, and the only Tell-Tale's are:
Main-Beam
Indicators
Hazard
Fog
Brake-Fluid
loggyboy - 28/8/10 at 08:16 PM
I dont recal seeing speedo being in MoT manual.
http://www.motuk.com/mot_manual/index.asp
Will be against construction and use regs I would imagine.
[Edited on 28/8/10 by loggyboy]
bigrich - 28/8/10 at 08:41 PM
speedo is not tested on the MOT, main beam warning is an advisory item and I believe a brake fluid level warning lamp is only required if the fluid resevior is not transparent and marked with a minimum level.
