IVA mechanical anti-theft
stevegough - 29/9/10 at 10:23 AM
Is the Sierra steering-wheel standard steering lock considered to fulfill this requirement? (steering lock engages into the teeth around the sierra wheel).
big-vee-twin - 29/9/10 at 10:26 AM
The mechanical anti theft has to deactivate to start the engine, so I think so.
dan8400 - 29/9/10 at 10:26 AM
Worked for me for SVA, i assume it would be ok. Someone to clarify with IVA book?
Dan
RedAvon - 29/9/10 at 10:41 AM
from manual
section 13A
"Method of Inspection
Check, in addition to the normal “ignition” switch, that the vehicle is permanently fitted with an anti-theft device or an electronic immobiliser that can be activated to prevent the vehicle being driven or moved under its own power.
A mechanical anti-theft device could be a steering lock or transmission lock. "
coyoteboy - 29/9/10 at 10:48 AM
So you could use a discloc ?
adithorp - 29/9/10 at 11:15 AM
It will pass if your still useing the standard ignition barrel and switch. You can't have something where it's possible to start and move the car while still having the steering locked.
Disc-lock won't do as it's not part of the car.
The mechanical lock has other things specified like it can't disable the brakes...
adrian
RedAvon - 29/9/10 at 11:38 AM
just for completeness as Adrian said re: brakes
Required Standard
1.
A vehicle MUST be fitted with either a mechanical anti – theft device or an electronic immobiliser
2.
If fitted to the Vehicle, a anti – theft device
a.
must be operational
b.
must not operate on any part of the braking system
3.
If it incorporates a mechanical part that acts upon a system used to control the vehicle
a.
It must Deactivate before the engine can be started
b.
It must be deactivated while the engine is running
c.
It must have a actuation which is a distinct and separate function from that of stopping the engine
Where the vehicle has no mechanical anti - theft device fitted:
4.
An electronic immobiliser must be fitted
Charlie_Zetec - 29/9/10 at 02:12 PM
I've probably asked this before, but will my solution be IVA compliant? I'm open to interpretation, but input from anyone who's actually been through IVA with similar setup is much appreciated!
I've not got the standard sierra ignition setup, but a dash-mounted keyed operation ignition switch, with a push-start button (all within steering wheel exclusion radius zone).
I've also got a removable steering wheel (keyed device, so can't be removed whilst vehicle is in motion as key is attached to ignition key on ring which is spot welded so can't be separated).
I have a master battery cut-off switch (yet to be installed), which can be mounted on dash, scuttle, or in engine bay.
Will the above combination suffice? I remember reading somewhere that there was the suggestion of a padlock-type setup on the handbrake level, but would this conflict with an interferance on the braking system? Surely the cable side is separate to the pedal operation, and as such you can still operate the brakes?
So many questions, but I'd rather get it right first time round! If need be I can install a Thatcham CAT2 electric engine immobiliser, in which case I'll ditch the battery master cut-off switch, but it's just another added expense.
Look forward to the range of opinions about to flood in....
RedAvon - 29/9/10 at 03:20 PM
does this help?
IVA says
"A manually operated battery master switch or a removable steering wheel would not be considered to be an anti theft device."
also says
"must not operate on any part of the braking system"
[Edited on 29/9/10 by RedAvon]
adithorp - 29/9/10 at 03:54 PM
For SVA you had to have 2 forms of security (is it just one now?). Standard Sierra ignition lock and steering lock counted as 2. I had a key operated ignition (like you Charlie) and an immobiliser and those counted as my 2.
From that I'd guess your ingnition lock will do.
Problem with your removable wheel (apart from the listing saying it won't do) is that you could remove the key from the wheel and start the car without the wheel on. Problem with battery master switches is the keys are all the same so not really secure.
stevegough - 29/9/10 at 04:23 PM
A big thanks for all the replies and discussion, seems I'm OK with my standard set-up (until the post - IVA 'fall offs occur - the bligdin sierra wheel being the first!!!)
Cheers, Steve.
Macbeast - 29/9/10 at 05:26 PM
" 4.
An electronic immobiliser must be fitted "
Eh ?? Really ?
stevegough - 30/9/10 at 10:43 AM
Originally posted by Macbeast
" 4.
Eh ?? Really ?
A good example of taking things out of context!
Because what (4) is preceded by is:
"Where the vehicle has no mechanical anti - theft device fitted:
4.
An electronic immobiliser must be fitted."
