My list
My list
It is a friend of mines car, he is nearly finished and asked me to check it out. Can you think of anything I have missed
[Edited on 20/11/10 by Mark Allanson]
Front
Left Suspension
Bonnet Catches
Mirrors
Bonnet
Right suspension
Right suspension detail
Interior
Seat runners
Pedals and Handbrake
Rear Lights
Fuel filler
Side cappings
LH Rear
Engine bay
Pedal box
Engine bay rh
Pedal box detail
Alternator
Front suspension
RH side entry
Seats
Chassis plate
Harnesses
Rear suspension rh
Handbrake cable and fuel pump
Floorpan
Rear suspension lh
Fuel hose
Top balljoint threads
Headlamp mounts
Sump and underside
Front lower
Front lower suspension
Clutch and underside
That fog lamp looks like a normal Landy-style rear lamp. Don't fog lamps have to be F-marked? (something to do with the reflector pattern I think)
The brake peddle rubber has fallen off
Disconnect the stack buttons so you can't navigate away from the speed reading(unless its a standard 8130).
You have U2U, Mark. Love the BRG colour.
