As above has anyone passed iva with these dash mounted rather than on the column?
Any reason to fail if they are?
Don't think it would be a problem - It wasn't an issue for SVA
My car passed IVA 8 weeks ago with all switches on the dash and inside the 127mm shadow of the steering wheel.
I did with no problem. Obviously they should be reachable by the driver.
excellent news cheers, what type of switches have you all used?
thanks
Ray
Hi my light switch is of a 135 fergie tractor have a laugh then look it up works perfect and passes good luck
I used toggle switches with rubber covers, but as stated before they were inside the exempt 127mm shadow of the steering wheel.
I bought the switches from: www.polevolt.co.uk/ who sell good quality swithes with all the necessary switching functions for lights, wipers, horn,
flashers and dipping.
I used switches from SVC, plus a toggle for the indicators. For the switches that were not labelled I a sheet of symbols and stuck them on.
RIOT Dash new
