I read in the new CBS catalog that the IVA has been revised to "outlaw" 3 point harnesses
Anyone know how accurate this is before I fit mine.
if you look at the IVA manual, it reads as if static 3 point belts aren't allowed.
But inertia 3 points are.
But I did pass my IVA last April with static 3-point belts.
so would a 3 point harness be classed as a static belt? i suppose it would.
Section 31 Table Note 4
an acceptable alternative to any of the seat belt types listed is an adult harness belt comprising a lap belt and shoulder straps providing the
anchorages satisfy section 19
Table in section 19 shows 3 Anchorage points required for front outboard seats.
[Edited on 14/1/11 by loggyboy]
As above re. harnesses are OK for IVA.
However if you are going to use your car in MSA competitions you are no longer allowed 3 point harnesses.
(i.e. - where the shoulder straps join into one and there is only one mounting.)
One of my fail points was I only had static 3-point belts. You need to have the self-adjusting 3-point belts or 4-point fixed.
Any one know if this is standard or just one vosa center's interpratation ?
I have had enough of moving goal posts.
Fail sheet says
" each seat requiring a belt must be fitted with a seat belt of the appropriate type as detailed in Annex 1 of Section 31 of the IVA M1
inspection manual
with the seat belt fastened and the seat unoccupied retractor mechanisms must take up any excess webbing
A retractor mechanism must be correctly positioned to ensure the correct operation of the belt "
Looking at the IVA manual -
" TABLE NOTE 4: The table lists the minimum required belt type. A 3 point retractor belt may be fitted where the minimum required is a 2 point
lap belt and an acceptable alternative to any of the seat belt types listed is an adult harness belt comprising a lap belt and shoulder straps
providing the anchorages satisfy section 19 "
Note 6: Some types of retracting belt might need help before they retract and harness belts due to their design will not retract however excess
webbing must be secured.
[Edited on 16/1/11 by Macbeast]
Ok thanks for the info macbeast. I couldnt get hold of Vosa so bassed on tyhe above ive chopped my roll bar about and fitted 4 points.
cheers
