Does a cannister fuel filter have to be mounted in metal clips or will cable tyes do?
Marty D
Cable ties on the fuel system is not a good idea.
Looks wrong
Does not give a good impression at IVA
Large jubilee clips might be better although some tintops use plastic straps to secure fuel filters, Peugeots for one
Mine is mounted with jubilees. I slipped a section of (motor bike) inner tube over the filter and made the bracket with a couple of little tongues. The clips around filter and over the tongues. Zip ties will work but don't look good.
Although it doesn't give a good impression at the IVA test, provided you have securely mounted the filter with cable ties, and there is no
chafing likely, I don't see why they would fail you for it. However, both my fuel filters are mounted 'properly' - one with an ally
bracket, the other with ally plate and a 'Terry' clip.
It depends on your build philosophy - do you want to do it 'properly' or are you happy with 'it'll do' ?
Cue the obligitary, illustrative picture....
I know cable ties are not that good but they are hand
Like the Terry clips
Got to go find them now
Thanks Marty D
