Just been looking at how I'm going to sort the fuel filler and hose for the Locost, and looking on Europa Spares, they have a filler cap and
housing. There are 2 types, one 'standard' and one 'IVA compliant'. The IVA one is £10 more than the standard!
I can't see any difference at all, and there seems to be nothing in the description to explain either. I think some companies are making a quick
buck out of the need to be IVA compliant
why dont you ring them up and ask them the difference?
Probably a leaded/unleaded restriction plate (read big washer).
^ that'll be it
OK, just rang them up, and apparently.....
....The SVA required the restictor (as you guys suggested) but for the IVA, they do not specify a difference because there are next to no fuel
stations left that do leaded so it's not an issue anymore??
Basically, they told me there is no difference between the 2 items.
Which takes me back to my first moan about IVA rip-off!!
If I hadn't asked, I would have assumed I needed the IVA compliant one when I would have got exactly the same product but payed £10 more !!!
Does it have the cap tethered?
can mind the last time I saw leaded or lead replacement fuel. Don't think the excess valve wear they all harped on about even happened, certainly I noticed zero difference in my old cars
I agree. I was talking to one of our local Kit Car club last week, and he has been running a 'leaded' Pinto on unleaded for the past umpteen
years, and has not had any issues whatsoever. Let's face it, the amount of miles the average kit car does it's going to take a hell of a lot
of years before any valve wear would be eveident.
Anyhow, I've decided to use the filler cap I already have complete with metal extension (it's the type where key stays in until locked) and
an adaptor from 57-51mm to connect it up to the tank and use flexible fuel filler hose.
The filler was going to have to be on the top of the back cover, but I think the flexible hose should allow me to put it on the back panel instead.
Originally posted by Daddylonglegs
I agree. I was talking to one of our local Kit Car club last week, and he has been running a 'leaded' Pinto on unleaded for the past umpteen years, and has not had any issues whatsoever. Let's face it, the amount of miles the average kit car does it's going to take a hell of a lot of years before any valve wear would be eveident.
Anyhow, I've decided to use the filler cap I already have complete with metal extension (it's the type where key stays in until locked) and an adaptor from 57-51mm to connect it up to the tank and use flexible fuel filler hose.
I had my filler in the back panel and it was next to impossible to fill up at the petrol station.
....The SVA required the restictor (as you guys suggested) but for the IVA, they do not specify a difference because there are next to no fuel stations left that do leaded so it's not an issue anymore??
This message is IVA approved so you will need to pay an extra £5 before you can read it.
:O)
I can also confirm that restrictor is not reqd for IVA - just one of the GREAT savings to be made now the IVA is in force
Th
is is the one I bought and fitted, and, as others have said, it is a bit of a pain to fill with it on the back panel - if you get the angle of
the nozzle right, and keep it moderately slow, its not too bad.
Hmm, thanks for the input guys
Not sure what to do now, I like the idea of the rear panel fitting, but if it's going to be a PITA then I might go for the top mounting
instead.
I will also be fitting a rack later, but I think if I place the filler cap correctly I should be able to still fill up without having to faf with the
rack.
Hmm, thanks for the input guys![]()
Not sure what to do now, I like the idea of the rear panel fitting, but if it's going to be a PITA then I might go for the top mounting instead.
I will also be fitting a rack later, but I think if I place the filler cap correctly I should be able to still fill up without having to faf with the rack.
lol! Leggy, good one
I think I'll make a decision on the spur of the moment over a beer or 2, that way if it's a problem I can always blame it on the booze
i'm trying to work out how to incoporate a hydraulically adjustable wing flap for the back end, and once the flap is fully open, it then pushes
up the rear cover, essentially a hydraulic fuel filler flap, and so therefor hydralically locking too
the fuel tank has a screw on cap on it, so not fillers on any panels for me!
Originally posted by blakep82
i'm trying to work out how to incoporate a hydraulically adjustable wing flap for the back end, and once the flap is fully open, it then pushes up the rear cover, essentially a hydraulic fuel filler flap, and so therefor hydralically locking too![]()
the fuel tank has a screw on cap on it, so not fillers on any panels for me!![]()
