Fuel Tank & Facet Pump
johnemms - 5/9/11 at 03:25 PM
Ok..
looking to fit my Facet Fuel Pump...
Now seeing as I made my own 'book' fuel tank out of mild steel...
Is there any reason why I can't weld 2 bolts to the 'empty' fuel tank ?
Then bolt the facet pump directly to the tank and add an earth wire ?
cheers all ..
r1_pete - 5/9/11 at 03:27 PM
I think you'll find that annoyingly noisy.
The pump should be rubber mounted on the chassis, but, if you welded a mounting plate to the tank and then mounted the pump on rubbers to that.....
[Edited on 5/9/11 by r1_pete]
johnemms - 5/9/11 at 03:54 PM
This thing when running is quite loud..
I'm only fitting an aero screen so I will be wind swept or helmet bound ...
I figure with fuel in the tank & the tank on metal straps with rubber lining it may be ok..
Just can't see a problem - makes life easyer & access to the pump filter too..
Ben_Copeland - 5/9/11 at 06:19 PM
Why ask the question if your going to ignore the advise?
It'll rattle like hell and if you dont hear it while driving you'll hear it at tickover.
