What's windscreen and what's side windows?
cloudy - 15/11/11 at 09:09 PM
For IVA what is defined as being the side windows vs the windscreen? I understand you have to have 90 degrees vision either side, obviously some of this will be given via side windows. I can't find anything that states how much of the view must be provided by the windscreen... Anyone had any dealings with this? I'm thinking of having a very thin windscreen, with wraparound side windows in plastic... (rather like the tramontana)
James
[Edited on 15/11/11 by cloudy]
Phil Smith - 15/11/11 at 10:25 PM
The technical difference is quie simple. if a window is attached to the front of the car it is a windscreen, if it moves with the door it is a side window. just for extra info if you have another window further back and not atatched to the front door it is a rear window (and as such can be tinted to an almost none see through level)
I understand this to be correct from a mate (a DOT MOT inspector) but I will try to get exact specs for you before weekend. Please don't forget to keep (and attach) the origional chassis tag from the donor car or your MOT will be a real pain in the ass (if they will even conduct test.
Phil
[Edited on 15/11/11 by Phil Smith]
Humbug - 15/11/11 at 10:50 PM
Phil
What's that about? You can't "keep and attach the donor chassis tag" because a kit/scratch-built car does not have the same identity as the donor and as such will need a new VIN (actually, reading your post it sounds like you might be one of our North American cousins in which case the rules may be different...)
iank - 15/11/11 at 10:53 PM
Could explain what you mean, the only way that would be necessary is if you are replacing the chassis with an OEM specification replacement.
cloudy - 16/11/11 at 08:10 AM
I won't have any doors! and the side windows start in the same place as the windscreen - the only difference is they are 90 degrees from the windscreen...
James
