Hi - I have heard some conflicting views on the following method of attaching cycle wings to the wing stays: (Basically dome headed bolts)
I know that I need to have trim around the edges, and also plan to locate the side repeater on the outer corner in the middle (to the wheel)
Basically some say no bolts at all, just glue the wings on to the stays, others say these bolt heads are fine?
Matt
Would think they are OK.
Hope you have used stainless steel bolts.
Just read the IVA manual about external projections.. I think they are fine..
good enough for me!!! Thanks alot!
Plus, it's extra weight on the wingstay- it's hard enough to stop them snapping as it is!
Ask anyone who's driven about 1000miles... your wing stays snap!
Sign of a true Locoster!
James
You can get your wing stays to last that long.
Im still on the same wing stays and wings after 7600 miles
But then, i did not make them as per the book design (crap)
