Can any one help
If I use the following :
Engine form Car A
Gearbox form Car B
Axels (Hubs) form Car B
Steering Column + Rack form Car B
DIFF form Car B
Prop from Car B
Brakes from Car B
New MK Chassis
Can I qualify for an Age related Plate?
Is GearBox, Hubs , Diff and Steering Column + Rack enough points?
If I get the V5 document for Car B to show Engine from CAR A . then pretend that my Donor (Car B) had an XR2 1600cc engine in it when I bought it
instead of the 1800cc serria engine -Would that cause problems.
Can you tell DVLA that an engine size in a vehicle has changed from 1.8 to 1.6 with out needing to present the vehicle for some sort of inspection?
Would they think this is a Tax dodge?
[Edited on 30/808/04 by mad4x4]
Is there a difference in Tax between a 1.6 and a 1.8?
i would put the engine from car A onto the logbook of car B . Sorted
Dont even need to do that, It only like a BEC. I got an age related plate You only need 2 items from Engine, Transmission, Axles (both), Steering
assy, Suspension.
Plus V5. So you shouldnt have a problem.
Cheers Ninja - I wasn't sure if Engine and transimisson had to be out of same car
But then again how could it in a BEC? DOH
