Emissions the pain of every bec sva…
Thanks to snoopy. Just a few comments on what I have done..
Fazer 1000 engine. Cat is welded onto manifold. Check for any leaks by covering tail pipe ( not with your hand!). Balance carbs and check Idle screw
turns from bike manual. I have fitted the patent snoopy goldfish tank valves and they work a treat and also a tail pipe baffle as per photo to keep
the gasses in...
/www.aquatics-warehouse.co.uk/acatalog/aquarium_supplies_ALGARDE__11.html
can supply the bits
