Front indicator location
pekwah1 - 5/11/12 at 11:38 PM
Hi guys,
Does the location of my front indicator look ok for Iva?
It's not fitted properly yet, just playing with where to put them, I'd like to use the striker's bracket if possible...
Regards,
loggyboy - 6/11/12 at 09:46 AM
looks like u'd struggle to get the angles needed there. Needs to be further forward to get viewable at 80 from outside (blocked by wheel at mo) and 20 degree from inside (blocked by nose)
loggyboy - 6/11/12 at 10:20 AM
[Edited on 6-11-12 by loggyboy]
SteveWallace - 6/11/12 at 11:22 AM
Just to be clear on the above diagram, they have to be no more that 400mm in from the widest point on the car, which is not necessarily the front wheel arches
loggyboy - 6/11/12 at 11:52 AM
Good point, indeed rear arches can often be slightly wider.
EDIT PICTURE TO SUIT.
pekwah1 - 6/11/12 at 06:54 PM
Thanks guys, well think its gonna have to be that onion get stalks or mounted on the front wings...
Nose mounted isn't really an option for me due to when I remove the nosecone/bonnet.
