I'm not 100% sure whether my car meets the anti-theft criteria for SVA so I was hoping someone else might know!
The SVA manual states that you need a "device that can be activated to prevent the vehicle being driven or moved onderu its own power",
other than the ignition switch.
My steering column includes a steering lock, is this sufficient or will I need something else to pass SVA?
If I do need something else then any suggestions as to what to fit are more than welcome - my SVA is on Monday!
Ignition and steering lock are sufficient. Good luck with SVA
Yep youll have no problems with that one. Good luck for Monday
Excellent, that's what I was hoping to hear, fingers crossed for monday!
Pete
