Exhaust heat shields??
Steve - 12/1/13 at 10:22 PM
Hi folks
Have not had chance to look up about heat shields in the iva manual but do you need to fit a heat shield to you exhaust on a 7 style car.
Have seen a few on here without them??
Ben_Copeland - 12/1/13 at 10:38 PM
No you don't. People sometimes fit them as shape edge protection.
You can't cut yourself but you can burn the crap out of your leg!!
Steve - 13/1/13 at 01:35 PM
One less job to do .
It's on passenger side so I'm good hahaha
meakin - 16/1/13 at 04:13 PM
Hi Steve, if you're not going to use a shield if you have a joint then make sure the bolts are "facing" inwards ie if you are using a standard exhaust clamp then rounded edge out.
I used an exhaust shield to cover the rear mount bracket which would not pass the IVA if left uncovered. (Standard bobbin to an L bracket)
Its worth a look at those edges/mounts and bolts/nuts as they all count in the "edge-sharpy pointed things" criteria.
Hope that helps and I'm not teaching granny to suck eggs.
Paul
renetom - 16/1/13 at 05:44 PM
Hi
As Ben said you cannot scratch your self or others
even if you run them over, but you can burn them
to death on your exhaust & that's fine.
good luck.
Steve - 16/1/13 at 08:31 PM
Cheers for that Paul I'll have a look at the bracket
