Got my SVA on monday and I'm a bit concerned that my exhaust mounting bracket might cause problems - has anyone got any idea whether the edges
marked below will pass or fail?
If they are likely to fail, how can I cover them up?
Pete
I suspect that it will fail, unfortunately.
Perhaps you can form some aluminium around it to present some nice gentle curves.
HI Scooby I think this will fail can you wrap some ally round the sharp end and fix it on the bolt of the clamp safety edge the ally first jacko
Thanks for the responses guys, I suspected it would fail but couldn't figure out how to cover it up, wrapping some ally around it sounds like a
really good idea!
Do I need to cover the nuts underneath the exhaust mount or will these be exempt because they are underneath facing the floor? I might cover them up
anyway just to be on the safe side, we all know how these things have a tendency to mysteriously fall off after SVA...
Pete
Originally posted by scoobyis2cool
Do I need to cover the nuts underneath the exhaust mount or will these be exempt because they are underneath facing the floor? I might cover them up anyway just to be on the safe side, we all know how these things have a tendency to mysteriously fall off after SVA...![]()
Pete
If the bracket goes all the way under and the clamp isn't actually holding the exhaust together, just take the saddle part off and smooth the
threads. Round the ends of the bracket off as well.
[Edited on 25/9/04 by Peteff]
Check out the post by Roadkill SVA fail, this problem was covered and picture of the clamp you need, hope this helps. Rusty.
Right, made myself an ally strip to cover up all the sharp bits of the exhaust mount. I used a length of ally, rolled the edges over to give nice
smooth SVA-compliant sides and bolted it down top an bottom.
It's pretty rigid and will hopefully keep the SVA inspector happy tomorrow!
Pete
You must be psychiatric Chris.
I wish you'd told me that yesterday Chris! Could've saved me the hassle of a retest!
Pete
