Having got my exhaust system back the other day, I decided to test it for noise using an i-phone app. First attempt the car wouldn't run
properly at all - minor panic - then realised that I had ran out of petrol (doh). Trip to garage with petrol can and then tried again and got 101db,
so two over the IVA limit of 99db. Not sure of the accuracy of the app, but don't want to risk it.
I need to check what the exhaust maker put in the can, if anything, but assuming that it wasn't a lot, do people think that some Acousta-fil will
get the noise down to where it needs to be, or is something more radical needed. I'm kind of surprised at the noise level given the size of the
can.
P.S. I had my CD of photos back in the post from VOSA yesterday, so I guess that I'm not far away from being offered a test date.
Did you do the test in an open area without any buildings near? Doing the test in a driveway etc could possibly give a false reading. Also might be worth checking induction noise.
If your worried about the noise u can always use a db killer for IVA loads of diff types etc
will kill the power but its IVA it will fall out on way home
Kev......
Db killer between 4 branch and pipe to can will reduce to about 96Db
That's a good point, I did it in a bit of a hurry just to see and it was within a couple of feet of the open garage and I didn't put the bonnet on. I have limited scope to move it without being illegal, but I can probably get a couple of car lengths away and put the bonnet on to see what difference I get. The IVA tester will be in a much more open space, so there will be a margin for error.
I did think about a db killer, but I don't want to drill a hole in my shiny new exhaust to put the locking bolt through and I'm not convinced that the IVA tester will not just fail me on the basis that he knows that its going to fall out two minutes after the test.
A hole drilled on the underside of the exhaust will hardly be noticeable. .
Currently having major trouble with this myself and have tried all sorts.
Anyway I've tried a load of different things and tested with a cheap sound meter (most phone ones aren't accurate up around 100db from what
I've read, due to the microphone). db killers and various home made devices in various positions etc. They will take a few db off but there
seems to be a limit to what you can achieve with them. I've got down to just under 98 on my meter but adding more and more baffles don't
take it any lower, even to the point that it's so restricted that exhaust starts leaking out of the silencer seams!
Things in the end of the pipe seem to have more effect than things further upstream towards the engine. Bear in mind though that it's a fail if
he can't get his emissions probe up the end, if he still needs to.
After all the tests, the most effect I've had was the simplest; a washer with a 20mm hole in the end, two 1" steel legs welded on, and
popped into the end of the pipe:
That's had as much effect as anything else I've tried, and easily inserted and removed.
That's not a bad idea, but, as you say, I'll only be able to fit it once he's done the emissions test. I don't want to have to
rely on the grace and favour of the tester to allow me to do this between the emissions test and the noise test, but I'll make one up as a backup
plan.
I think that my first fix is going to be to try Acousta-fil.
I've put a post in the 'wanted' section to see if anyone in the Nottingham/derby area has a proper db meter that I could borrow as
I've started not to trust my app.
At my SVA test my rev counter was under-reading by about 20%. I only realised afterwards
Of course having twin pipes it means the dBs are coming
out of both sides and they only measure on one side so it was never going to be a problem even with a straight through pipe with the restrictors
chopped off.
Originally posted by The Black Flash
After all the tests, the most effect I've had was the simplest; a washer with a 20mm hole in the end, two 1" steel legs welded on, and popped into the end of the pipe:
The emisions probe would still go in through that plate.
Ba careful with accousta-fill as the on-line amount calculator is thought by many to cause overpacking and so not enough silencing.
I know what you mean. I tried a few of the on line calculators and got answers that varied by a factor of two. I've gone for the lower amount
as there seemed to be more at this end of the range.
I don't weld so I'm also going to cut a couple of baffles as shown in The Black Flash's photo with different sized holes and see what
happens. I'll do them in thin aluminium first and just push fit and then convert to mild steel with a small bolt fit if I find a size that
works.
[Edited on 24/3/14 by SteveWallace]
All of the ones that I've seen fit on the tail pipe. Are you saying that you can get them to fit further up stream? Not sure that I can get one to fit the tail pipe as its a rolled end and turns through nearly 90 degrees.
