does anyone have a pair of iva wing mirrors with indicators that I could beg, borrow or swap for beer tokens to fit an MNR Vortx that will get me
through the IVA
I do have a set of the very small repeaters, so if anyone can recommended a pair of mirrors that I could mount these in with a hollow shaft to run the
wires down that's also an option
IVA is booked for the 1st and this is one of only two outstanding things.
I could mount the indicators in the front wings (anyone got a picture of the best location) but its being recommended to put them in the wing mirrors
is it ok to cable tie the brake line flexi to the wishbone at the front or does it need something more substantial ?
thanks in advance for any answers
Can't you 'pig tail' the brake lines to avoid having to attach them to wishbone at all?
As for mirrors I've not seen any aftermarket ones with built in indicators that will pass IVA,they don't have the rear vision required.
I don't think it's allowed to cable tie to wishbones on the front, but as Kev said , put a curl or pigtail in the line, that got me
through.
[Edited on 16/9/15 by kingster996]
MNR have a set they might lend you if you ask.
i got through with a 'pig tail' in my lines too.
I think you need to avoid brake flexis touching the wishbones at all, hence the pig tailing.
Ian
thanks for the replies
can you clip the brakeline to the wishbone with something like this (I will try pig tails but if it fails on them want a second option)
5x Lockable Pipe Hose Cable Electrical Wiring Holder
MNR's mirrors are all in use :-) Chris said he would send me some pics, just waiting
these are the mirrors I have got
http://www.carbuildersolutions.com/uk/carbon-effect-stalk-mirror
will they get through IVA ? - I am going to see if i can mount the indicators on them this weekend somehow, the dims seem to imply they are complaint,
just want to be sure as I am running out of time to get things done
thanks in advance for any thoughts
[quotethese are the mirrors I have got
If you do stick some indicators on your mirrors you'll need to come up with a way of routing the wiring so it looks like a permanent
installation, ie not just running around the outside.
I drilled holes in my cheap crap mirrors and used Araldite to glue trailer marker lights in,
then used a black permanent marker to cover the glue.
The stems weren't hollow, so as you can see in the second pic the wire runs under the stem.
I've got to admit, they were bright. They really lit up my eyes in the dark.
They look shite amateur (IMHO) and as soon as they passed IVA I took them off and fitted
my Mitsy repeaters back on, together with bullet mirrors.
Paul G
I have decided after much thought that i am going to put them in the rear arches -- i dont want to but it seems the best - mainly i dont like it
aesthetically, but ultimately I want it to pass and it will be permanent - however Paul has got me thinking now - however if i stick them on that
means another set of mirrors to buy afterwards
i checked cbs website none of the mirrors say IVA complaint anymore
quick question on front indicators
i need to extend these to be within x mm of the side of the car. (need to check the regs for the dim) I am planning to use plastic electrical conduit
tube to extend them - will i get away with that ?
I am guessing you sold your mirrors Paul G - i saw your post come and go....
yes your right 5 out of 43 are IVA complaint - I tried their search and iva section previously both didn't return anything and checking a large
sample of them didn't, but checking all 42 I can see 5 do - just they are all not for me, but I might have to get something to get past iva
Looks like I will need to check for at least an e mark and the glass size tonight
thanks
I have decided after much thought that i am going to put them in the rear arches -- i dont want to but it seems the best - mainly i dont like it aesthetically, but ultimately I want it to pass and it will be permanent - however Paul has got me thinking now - however if i stick them on that means another set of mirrors to buy afterwards
I bought these:
http://furoreproducts.co.uk/mirrors/85-e-marked-mirrors-iva-ok.html
Really nice quality and IVA compliant. Cheap enough to buy and sell on again after you've passed and they 'fall off' the car
having looked all afternoon I think I will go with the arches, car is short enough after a quick check last night (2600mm)
the issue Paul was - will I have to drill another hole I didn't want to- was on the train easy to read - hard to reply in the squash
I will get those ones, for 14 quid I am beyond caring I just want it to pass, time is very limited for me - so the more I can do to be sure the better
:-) I would use more then 14 quid in fuel going for the retest
thanks
I understand about the extra holes.
My black plastic ones have 2 holes, o o thus. With one for the wires it becomes 3, ooo
My bullets have 2, o o , so they fitted and covered the now redundant middle hole.
My only reservation with a single nut fitting is that if they get knocked they spin and undo.
On old motorbikes the left mirror would undo when you got to a certain speed due to wind resistance,
then a smartarse came up with the idea of a left hand thread on that side and right hand on the other.
Good luck with your test
Paul G
thanks Paul, lets hope so, not much time left for final sorting
mirrors ordered, indicators mounted on the arches on the weekend - just wiring to finish off, steering wheel - well I am still not sure about that, I
fitted the crash pad I made but it looks terrible - front indicators - almost made the extension tubes, I am using 20mm electrical conduit and hoping
that will be good enough
