Morning all,
I had a vision while stuffing my face with Turkey yesterday.. If I bought a TVR chassis and cobra body how the bloom in hell could I register it!
If I used a Dax shell could I register as a Dax after IVA/SVA, ISOMOT (whatever it is these days)
Or could i register it as a new kit car (without a q plate)
Any advice welcome
Ps Happy Boxing Day
I think, if the chassis is not modified then it should remain as a TVR.
Yep, just a rebody, no iva needed, keeps the same reg, not sure who you need to tell about the rebody, but it keeps the TVR registration
If your keen on IVA and want a new reg why not build a new Dax?
Or are you wanting to bodge the 2 together for some vision/reason???
Thats why topgear used a tvr chassis for the hammerhead eagle ithrust.
The chassis and running gear I saw has no ID (from a damaged TVR)
The TVR chassis just looks allot stiffer and stronger than the DAX and I wanted to build a fast/track car.
So yo can build any thing you like and IVA it... With a q plate.
But can you get an age related?
age related needs a specific "registered" donor vehicle
OK,
After a few weeks, many E-mails and lots of calls i have sourced a TVR chassis, running gear (Minus the engine) with a V5
If i use the complete chassis and do not alter it i can use the TVR reg. BUT who do i need to tell about "rebody"
And am i correct.
Thanks guys
You should inform DVLA of any engine change , numbers , capacity etc . Not sure who or what you need to do with a rebody but I suspect only your insurance company?
I would tell the dvla as they might want to reflect the change on the body style or notes section of the V5. And of course your insurance company!
