Floor Mounted Pedal Box Bolts
K19 - 13/6/17 at 12:43 PM
My build has a floor mounted pedal box, and this means there are bolts through the floor and show on the underside of the car.
Will these need covers/anything else, or does it fall within the exempt area and doesn't matter?
adithorp - 13/6/17 at 01:59 PM
The underside is exempt from the edge radius rules.
mcramsay - 13/6/17 at 04:31 PM
I put nut caps over all exposed nuts and bolt heads externally visible on the car, not needed but it pleased the IVA man as it looked like I had put some thought into it!
scudderfish - 13/6/17 at 05:20 PM
If you're likely to injure someone with the radius on the nuts/bolts, then those nuts/bolts are probably the least of their worries.
