I've used Gearbox, Steering (Column), Hubs and CVs (actual driveshafts were fabricated though) amongst other things from my donor which I have a
V5 for but the engine came from another car as the donor's was very high mileage.
Has anyone had this or similar on Built Up Vehicle Report:
Transmission: Gearbox and CVs from Donor
Steering Assembly: Column from Donor
Engine: Different car (have receipts etc)
Suspension: Hubs from Donor Car
I guess hubs for suspension is pushing it a bit but how about gearbox and steering - two major components?
I realise it's probably 'against the rules', but how would they know if was a different engine? How do they know that the previous
owner hadn't done an engine swap before you got it? I believe the engine number is on the V5, but I also believe that they don't take that
as an indication that is the donor engine, because they don't take the V5 as proof of engine age.
And on that subject, the only thing you'll need to be wary of is the engine age for emissions.
Hmm, hadn't thought about that. I guess there are lots of engine swaps where the owner doesn't update the V5.
I have a letter from Ford for engine age so that's not an issue.
I wonder if any others have got away with this?
What happens if they aren't happy with your story - do they just issue a Q plate?
[Edited on 5/8/17 by DaveGreaseMonkey]
Originally posted by DaveGreaseMonkey
I've used Gearbox, Steering (Column), Hubs and CVs (actual driveshafts were fabricated though) amongst other things from my donor which I have a V5 for but the engine came from another car as the donor's was very high mileage.
You had lots more parts though, I'm wondering if transmission and steering will be considered 'major' parts.
Do you have to have VIN plates or is that just belt and braces?
code:
You must also have 2 other major components from the original vehicle from the following lists.
For cars or light vans:
suspension (front and back)
steering assembly
axles (both)
transmission
engine
