In attempt to overcome the mirror issue I have decided to fit a camera.
one question should the screen be always on or only when reverse is selected?
could find nothing in section 08 indirect vision
except:- Camera systems will only be required to meet RS4, RS6 and RS12.
I would guess always on/(ignition on), since you look in the mirror as you drive.
certainly would wire it that way for iva
Contact the IVA centre and ask. Runs in my mind though that Bluemoon is right.
Unless the rules have changed (they might) you can't have CCTV set-up instead of a mirror... I would read the IVA manual...
did you get anywhere with the camera installation?
Does that read that you CAN use a camera and monitor?
Sorry for the late reply test got canceled twice had to wait 8 weeks to get a slot.
Well according to the inspector only "type approved" camera are acceptable
he would not be drawn on the wording of the IVA manual ;-)
I have just emailed DVSA to ask them to clarify.
'Could you advise on the use of reversing cameras on non type approved vehicles (ie kit cars)? Is it acceptable to use them in place of
mirrors?
Many Thanks etc etc'
"he would not be drawn on the wording of the IVA manual ;-)"
How unusual for IVA inspectors!!
I found this
https://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/2013/R046r5e.pdf
Uniform provisions concerning the approval of devices for indirect
vision and of motor vehicles with regard to the installation of these
devices
'Could you advise on the use of reversing cameras on non type approved vehicles (ie kit cars)? Is it acceptable to use them in place of mirrors?
Just re-posting here if someone searches for cameras
Well Done LoggyBoy for getting the clarification.
So I was totally correct in my initial assumption
Just for reference I did not use a £30 cheepy reversing camera of ebay.
It was a Sony CCD effio-v (I use them for diy nightvision and FPV), I spent some time playing with different lenses
to get the best FOV (Field of View). if the fov is too wide you will see lots of distortion to narrow and you will not meet the requirements and
magnification becomes an issue.
The biggest compromise was the screen as I had limited space to mount it (did not fancy building a custom mount just for the test)
so ended up using a 5" with fairly low resolution in my opinion is was "just" good enough for the test would have much preferred a
7" -10" display...
If I was to do it again for real and as a total mirror replacement would go for full HD 1080p camera (minimum 720p) along with a 7" full HD
screen must be daylight view able high lux rating or one with a sun shield.
"So the inspector in question might need to review his stance"
Good luck!!
If you took it to a different station they would probably accept it with no issues at all!
Looks like they've added the requirement for approval back in. it now states:
CMS will only be required to meet RS4, RS6, RS12 and RS13
RS13: CMS must be approved to the requirements of UNECE Regulation 46.04
paragraph 6.2.2; documentary evidence will be required.
They must get some guff bodge jobs in to be fair.
Meaning they would accept something documented as having daylight readable attributes rather than certification docs? Did you get anything written to back that up?
I looked up secn 6.2.2
pages 16-18 in this document
https://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/R046r4e.pdf
both the camera and screen are tested, I wonder if there could be an 'approved' aftermarket kit
