Hi everyone, I'm just after a bit of advice please...
My 1.7 crossflow-powered Sylva Striker failed its IVA the other week on a few minor issues (a couple of edges needing rounding and side repeater
position) but it was also about 1dB to loud, so failed on noise. I did a bit reading on here and thought that the best way to go might be to fit a do
killer. I've just tried it out and it had the opposite effect and increased the noise by about 25dB, which I thought was quite impressive! So I
am wondering what I have done wrong?
The silencer is the original re-packable Sylva item. I'm running twin dellorto 40's which only have filter socks fitted currently. The db
killer noticeably increased induction and general engine bay noise, as well as a high picth whistle at the exhaust outlet as the air accelerates
through the killer.
The killer itself had to be shortened to around 140mm but still has plenty of baffles. It also came with some packing material which I fitted.
Any thoughts on what I've done wrong or what to try next would be most welcome.
Knockout
I can't help with a solution, but I have to say that if you've increased the noise level by 25dB, it's very impressive indeed: when you
figure it out, patent it - there's every chance that it could be used as a military weapon!
If I remember correctly from university, on the logarithmic scale, an increase of 6dB equates to a doubling of the sound energy, so you've
somehow managed to more than quadruple the amount of energy that is being converted to noise!
I was only using an app on my phone to take the measurement so was never going to be that scientific, but even without looking at the results I knew that it wasn’t going to be good! I might be on to something!
My 1.7 crossflow-powered Sylva Striker failed its IVA the other week on a few minor issues (a couple of edges needing rounding and side repeater position) but it was also about 1dB to loud, so failed on noise. I did a bit reading on here and thought that the best way to go might be to fit a do killer. I've just tried it out and it had the opposite effect and increased the noise by about 25dB, which I thought was quite impressive! So I am wondering what I have done wrong?
The silencer is the original re-packable Sylva item. I'm running twin dellorto 40's which only have filter socks fitted currently. The db killer noticeably increased induction and general engine bay noise, as well as a high picth whistle at the exhaust outlet as the air accelerates through the killer.
Knockout
Originally posted by Sam_68
I can't help with a solution, but I have to say that if you've increased the noise level by 25dB, it's very impressive indeed: when you figure it out, patent it - there's every chance that it could be used as a military weapon!
If I remember correctly from university, on the logarithmic scale, an increase of 6dB equates to a doubling of the sound energy, so you've somehow managed to more than quadruple the amount of energy that is being converted to noise!
Thanks for the advice, I'll try repacking if I can get the silencer apart.
I was measuring at the exhaust outlet.
Anyway, thanks again
I had my phone sat on an axle stand in approximately the correct test position (as they had at the IVA test) with the microphone towards the
exhaust.
It did occur to me that maybe I had the killer fitted the wrong way round. I've got the widest section down-stream?
I will have to re-pack the exhaust I think. In the meantime I've moved the killer to the section of pipe between the manifold and silencer to see
if it makes any difference.
I'd repack with accoustafil as it's far superior to anything else. Use the online calculator (just google it) but only use 2/3 of the amount it recommends as it's been found to give best silencing at that. Once you've repacked run it up to temp to melt the quilting threads and allow it to expand before measuring level.
Easy way to reduce noise is to just turn the outlet it so it points at the ground or under the car, once tested put it back where you want it.
I have a similar problem that is not that easy to sort as I sprint so have to be under 105db tested at every event, I am now looking at making a
spiral baffle as I cannot fit any more cans into the system
[Edited on 28/5/18 by mark chandler]
Thanks for everyone's advice on this...just a little update...
I was struggling to get my silencer apart (due to a welded bracket!) so I thought I'd give the db killer one last try, this time just after the
down pipes and upstream of the silence in a section on straight pipe. This seemed to have a much greater impact (in the positive direction) lowering
the measured noise by 4-6 db. So hopefully that will do the trick for now! I just hope it doesn't affect the drivability too much).
In its previous position it was fitted just after a 45 degree bend (immediately prior to the exit) so I guess the air didn't flow into the killer
very smoothly.
Thanks again everyone.
re-check your emissions before IVA. I put my DB killer in the same location and it backed up all the gases and made it run richer! Just scraped through on my re-test because of it.
Interesting point, I didn't realise that they would re-test the emissions. Is that done automatically as I've made a change to the exhaust? I thought that they would only re-test the fail items. Is there any other areas that will get another look? Thanks
They shouldnt, but will depend what side of the bed they got out of that morning!
