An acquaintance has an aim to build a replica of the 1930's BMW 328 car shown below.
Having built a kit car I'm relatively familiar with the SVA (at that time) rules.
The car is intended for road use only - no track days or competitive use.
Would the same rules (IVA now) apply to his project or would the DVLA/VOSA treat the car differently?
Thanks,
Nick
[Edited on 7/9/18 by nick205]
depends what chassis you use - if you use an unmodified chassis from a suitable donor vehicle you'd get away with calling it a re-body
if its a new chassis then it will need an IVA
[Edited on 6/9/2018 by mcerd1]
Unless your friend could find a chassis based car with the same wheel base that was already registered and use that as the underpinnings it would be just the same as any kit car through the IVA. Going to cost a heap of money regardless
He already has GRP body mouldings for the car.
The mouldings don't have opening doors and he's happy with the idea of climbing in/out as per a 7 type kit car.
Chassis wise he plans to build it around a Locost type chassis. This could be a fresh built chassis or potentially a registered Locost stripped back
to take the body he has.
His real concern at this stage is which rules it will have to comply with and tests/inspections it may have to undergo. Whilst he has no desire for
it to be unsafe he equally wants to retain the look of the original car (we appreciate the two objectives may clash with each other).
I'd start with an already registered kit car - similar style, similar track/wheelbase (as Mr Whippy said) something like/similar too a Pilgrim perhaps - a re-body then wouldn't need an IVA.
A re-body of an already registered car seems the better option to me!
He knows I built a kit car before and has asked if I'd consider dojng this car for him. Whilst I love cars this one just doesn't do it for
me and it wouldn't be mine when finished so it's a "NO THANKS" to that question.
is there any database for car wheelbases that he could search through
paul
paul
Putting a new body on an already registered kit car seems a sensible way to do this.
There is a build thread on the Madaboutkitcars Forum of something similar. Someone is putting an aluminium replica body of a 1957 Ferrari 250
Testarossa on a Locost. I will try to find the link.
paul
Not aware of one, but that doesn't mean there isn't!
paul
Wouldn't worry about it, if you go for something with a fairly simple chassis and a live axle then 'adjusting' the wheelbase is pretty straightforward
The bigger issue will be width, I suspect a 328 is pretty narrow, so it'll be herald / escort / morris track width, I'd be looking for something with a ladder chassis based on one of them I reckon.
http://www.madabout-kitcars.com/forum/showthread.php?t=6588
One off the wall alternative to consider is getting hold of a Dutton vin and log book and simply transferring it over.
Actually in all seriousness, this could actually be a legitimate use of a Dutton chassis if the wheelbase can fit & you can get the chassis under
it without (obvious) modification.
Personally if you can find something with the right wheelbase I would have thought a Robin Hood or Vindicator might be a sensible starting point, or
go for something that already starts out more like the finished article, like a Bulldog (as already suggested) or possibly Spartan - fine as long as
you don't mind old running gear
One other possibility would be a Scimitar? Tho' a bit thin on the ground now
https://www.carfolio.com/specifications/models/car/?car=56551
mm inches
Wheelbase
2400 94.5
Track/tread (front)
1150 45.3
Track/tread (rear)
1220 48
Length
3900 153.5
Width
1550 61
Height
1400 55.1
Ground clearance
200 7.9
length:wheelbase ratio
1.63
Kerb weight
830 kg 1830 lb
mm inches
Wheelbase
2400 94.5
Track/tread (front)
1150 45.3
Track/tread (rear)
1220 48
quote:also 2cv maybe
Originally posted by jps
Triumph Herald pretty close on wheelbase and track
wheelbase ok, but 14cm wider at front. (oh and it might drive the wrong wheels)
Wheelbase 2400 94.5
Track/tread (front) 1260 49.6
Track/tread (rear) 1260 49.6
Simply weld a few bits of metal together and screw on some old number plates....job done.
Thus:
https://www.ebay.co.uk/itm/Classic-Mini-Kit-Car-Tax-Mot-Exempt-Project/302871811240?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
[Edited on 7/9/18 by owelly]
It also depends how accurate that body is dimension wise.
There was a look-a-like kit for Scimitar chassis
[img]http://i167.photobucket.com/albums/u143/rogp/New-Scimitar-01w.jpg~original[/img]
[Edited on 7/9/18 by ettore bugatti]
Just from an IVA point, the windscreen looks like a fail, and the spinners, and not sure about the indicators on the wings
but apart from that the body appears to be designed with IVA in mind in 1930 !
