Booked my IVA via the online TAS system submitting various documents, photo`s and the application forms etc. It was easier than I thought. Within 5
days DVSA came back to me saying all good and I was able to book my test for the end of Feb which surprised me. Thought it would take longer. I
noticed on DVSA website though that they have a service level agreement to get 95% of IVA applicants booked onto a test within 4 weeks.
Due to the current file upload problems on LCB I have put some photo`s on dropbox. If anyone spots anything let me know!
https://www.dropbox.com/sh/ky2ukfpqcpib8ks/AABYrkyKKtIxTry35RakDkQGa?dl=0
Looks good to me mate, you have been busy!
I'm glad it worked out for you. It's defiantly a change that's worked for the better. good luck with your test
Excellent looking car, good luck with the test. But I have to say, I'm not a fan of the padded dash, it's the only thing that stands out as "home made", the rest of the car looks very professional.
Will be very interested to know how you get on with the emissions on the engine! I had a lot of issues with my 4AGE and had to end up taking it out!
Have you changed the screws holding the headlight covers?
I would use socket head button screws with flange.
Nice and flat with a large surface to clamp the cover.
Nice car.
Slater – I agree about the dash, I couldn`t get the stretch marks out fully! I do plan to upgrade the dash post IVA though.
Engine wise I managed to obtain an e-mail from Toyota confirming my engine number date of manufacture was in Nov 1989. With that in mind I understand
the emissions test will be a non cat test with max limits of 3.5% CO2 and 1200 ppm hydro carbons? Is that correct?
The screws holding the headlamp covers are small heads. They don`t stick up more than 5mm from the surface so should be ok but I think i`ll order some
of those flanged button head allen bolts anyway as they seem slightly shallower, thanks for that.
Great looking car. Good luck with the test. Where are you getting it tested?
Chris
Derby. Is that where you went last week?
I could be wrong on this....... the engine should be pre-1995 in order to qualify for non cat test with max limits of 3.5% CO2 and 1200 ppm hydro
carbons.
This was the case for my SVA back in 2009, but maybe they have changed the qualify date since then????
Page 44 of the manual states any 4 wheeled vehicle with an effective date between 1/8/86 and 31/7/92 qualifies for non cat test with limits of 3.5% and 1200ppm. My engine is 1989 so should be in this bracket.
ahh i remember one of your previous threads now! You should be fine then. Toyota would not help or give me any info at all, they refused to speak to me about it after a while! VOSA would not accept the letter that RAW have from Toyota, so i was screwed! Good luck though, you will be fine!
OK Snippy, I stand corrected. Looks like you've done your homework, so hopefully you will avoid the big Wahala I had on the emissions on my SVA
day, have a read of this...
http://www.locostbuilders.co.uk/viewthread.php?tid=108014
Just read your old thread, blimey, talk about stress! You`ll never forget that day. Great achievement to get a first time pass. I did an old SVA back in 2006 and failed on 3 points. Couldn`t fix on the day though.
