Hopefully somebody can help with a query about having an MOT after SORN.
I built a Fisher Fury a number of years ago which was tested and registered and run on the road for a few years. For a number of reasons it has been
off the road for quite some time and SORN applied for. However, the current restrictions due to COVID have given me time to sort the many jobs that
need doing on the car and it should be fully sorted by the spring.
My question is with the car being off the road for so long will only a standard MOT pass be sufficient to make it road legal again or is some other
form of testing required?
Than you
Paul
Just an MoT is only legal requirement, sounds as tho' you're having a good look around the car anyway, I'd take a good look at tyres if
it's been standing for a while as can result in tyres being out of shape or sidewall cracks appearing - you don't want a tyre to let go on
the way to MoT.
You obviously need insurance in place, but you're legal to drive to & from a pre-booked MoT without road tax, best to aim at putting back on
the road near the start of a month as avoids paying for a month of tax you've not used
Many thanks very much appreciated
Regards
Paul
Don't give the DVSA idea's
I did my fury last year after being off the road for 5 years and just a standard MOT was all that was required along with insurance.
Had to bed the brakes in a bit on the way so make sure you have a bit of a run.
best of luck Pete
Thanks Pete,
Doing a fair bit of work on the car so it will need a good shake down before I visit the test centre.
The car has been garaged since it has been off the road and raised off the ground on a hydraulic hoist so hopefully the bits I am not doing any work
on will be ok.
Going to enjoy a good few months now back in the man cave and at least I should have something to thank COVID for!
Regards
Paul
paul27 where are you in the country we are a kit friendly garage in north lincs if that helps
Hi
Based in South Wales near Cardiff, so unfortunately a bit of a distance from you.
Regards
Paul
You did say it needed a good shake down
As in understand it, if its more than 40 yasr old it doesent even need and MOT,
next year my lancia Beta spider will be 40 , rusty as hell and it wont need an MOT , brilliant
